June 9, 2008, 04:09 |
Conjugate Heat Transfer query
I'm wanting to know the temperature soak performance of a solid body which is surrounded by a fluid. If I use the Conjugate Heat Transfer feature in CFX will that tell me anything about the temperature in the solid body - I would expect it does not and I'd need to use the Fluid-Structure Interaction. Is CHT just about using a solid as a source or sink for heat energy whereby only the behaviour of the fluid is to be understood? Thanks. |
June 9, 2008, 08:03 |
Re: Conjugate Heat Transfer query
If you want to observe the shrinkage of solid body due to thermal shock , then it is not possible in CFX. Other wise You can always obtain temerature profiles on solid fluid interections.
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
Conjugate Heat Transfer in rhoPisoTwinParcelFoam | jabecker | OpenFOAM | 0 | June 23, 2011 09:19 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Conjugate heat transfer problem | hvem10 | FLUENT | 2 | October 29, 2009 17:31 |
