floating point exception
Old   November 10, 2008, 02:35
Default floating point exception
mojtaba
hi everybody I tried to model a viscous flow by "pressure inlet" and "pressure outlet" in CFX 5. But there is a trouble and CFX announced "floating point exception" and suddenly solve is terminate with error. I can't solve my problem. I studied CFX manual. It offers that applicants should use "velocity inlet"! But my problem is that I have to use "pressure inlet". I applied inlet, outlet and opening boundary conditions together but solve failed too soon. What can I do? I would be very grateful for any advice.
Old   November 10, 2008, 04:06
Default Re: floating point exception
Adam
I would try running with a different scheme or timestep. Often its the path the mathematics take to arrive at the converged solution which causes the problem. Trying a different scheme or timestep alters the path slightly, which sometimes avoids this.
Or you can try using double precision.
Cheers
Adam
Old   November 15, 2008, 06:58
Mojtaba
Hi and thank for your attention I studied your comment. I'll try to solve my problem in regard to your advice. I'll announce you results. Good luck.
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 16:34
Finished simulation doesn't start: floating point exception [Divide by zero] MaxCFD STAR-CCM+ 3 June 26, 2011 10:31
reactingFoam floating point exception pajofego OpenFOAM 0 November 6, 2010 17:29
Cannot Open .sim (Floating Point Exception) trex930 STAR-CCM+ 1 July 30, 2010 06:51
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
