transient time reg
Old   December 12, 2008, 08:30
Default transient time reg
NVSD BABU
HI all when we are using transient scheme,how to take total time in simulation.I did an experiment,to get steady state it took 4hrs.In the simulation should i give 4hrs as total time?,if this is the case how to take time steps.If i give time step as 1s and no.of coefficient loops as 10,the solver takes weeks to solve.
please tell me how to solve this type of problem.
Thanks alot in advance
NVSD BABU
Old   December 12, 2008, 14:00
Default Re: transient time reg
Pratik Mehta
Ya, thats true that 1 sec with 10 loops and depending on your physics and mesh will probably take time. But why don`t you try to find of the timestep size which is the time scale of your problem. In case you are not sure you could make a trail n error about the timestepping .And you can input total number of timesteps ( Number of iterations).
I hope this helps
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Time value of timestep in Transient simulations siv CFX 3 December 8, 2005 11:15
