March 11, 2010, 16:26 |
Hex versus Tet
Rep Power: 17 |
I am running a CFX problem with laminar flow through a duct. The fluid flows through some fins in the middle of the duct.
When I mesh with tet, for the same number of nodes, the run times for the tet are significantly greater than those for the hex. It seems that it takes much longer for the tet mesh's solution to converge (a lot more iterations). Why? I am assuming that the matrix size is the same as it is proportional to the number of nodes, correct? Also, for a hex mesh, the number of nodes and number of elements are about the same. For a tet mesh, the number of elements is much larger than the number of nodes. Why? Thanks so much for some greatly needed explanations! |
March 11, 2010, 23:41 |
Rep Power: 143 |
The node/element counts is explained in the documentation, in the section which describes the control volumes.
How big an effect hex vs tet makes is problem dependent. If you are doing a simple incompressible flow it won't make much difference. If you are doing complex stuff like free surfaces, shock waves, etc etc the improved mesh quality in a hex mesh can make a huge difference. |
[ICEM] how can i create a consistent transitions between tet and hex? specifically my model? | snailstb | ANSYS Meshing & Geometry | 3 | March 15, 2010 20:26 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 02:34 |
poly, hex dom, hex, tet | azmir | Siemens | 0 | October 31, 2007 19:24 |
hex mesh vs. tet mesh (for FEM solvers) | Sam | Main CFD Forum | 0 | July 1, 2005 15:11 |
HEX vs. TET | Selina Tracy | Main CFD Forum | 1 | May 10, 2001 05:19 |
