August 18, 2010, 04:46 |
Laminar Flow
Pavelistyj
Hi all ,
Do anyone has a tutorial on laminar flow . I'm trying to simulate laminar steady state flow in rigid pipe - I have good results , but there is some velocity on the wall (that was defined as no-slip wall) . Do anyone one what the problem may be ? Thanks , Pavelko . |
August 18, 2010, 06:52 |
Rep Power: 143 |
I seem to remember answering this question before. There is no error with the implementation of no slip walls in CFX. The problem is that your wall point is either not exactly on the wall or has included the control volume adjacent to the wall and is therefore not zero.
August 18, 2010, 07:35 |
Pavelistyj
Just to be sure that my approach is right :
----------------------------------------- Geometry - I've created the cylinder , defined it as a fluid , meshed it , and set up the outer radius of cylinder as a wall . Is it right ? |
August 18, 2010, 07:39 |
Rep Power: 143 |
Your approach is correct. The problem is in your post processing, not the simulation.
August 18, 2010, 07:51 |
Pavelistyj
Thank you very much ! Those are good news for me
Boundary Layer of Laminar Flow over a Flat Plate | Blasius_Pohlhausen_Crocco | Main CFD Forum | 12 | September 30, 2013 17:35 |
How to enforce laminar flow while using k-e | Grzegorz Kondora | FLUENT | 0 | January 28, 2009 10:35 |
a laminar flow and heat transfer problem | majestywzh | FLUENT | 1 | April 16, 2003 03:39 |
grid for laminar flow | kim | FLUENT | 2 | April 4, 2002 02:44 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
