static pressure went outside the limite
Old   December 30, 2010, 08:20
Default static pressure went outside the limite
jarrai
jarrai is on a distinguished road
I simulate thermal-hydraulic performance of the heavy liquid metal,during simulation run i get a Note message:
"while evaluating static entropy,static pressure went outside the limite. it minimum value was -9.8327e3.the bound errror was handled by clipping if this simulation prosist,consider increasing the table range".
Can anybody help me understand the Note message?
jarrai is offline   Reply With Quote
Old   December 30, 2010, 08:28
Dmitry Semikin
Dimone is on a distinguished road
Obviously, you use some real liquid model. As I understand for myself for those liquids interdependencies of physical values are described analytically, but passed to solver as table of values. So, you should define the range in which those tables should be precalculated (the range in which material properties can vary). In properties of such materials in second tab (do not remember name exactly) at the bottom there is a property - something like "table range". Give there the min and max values for all physical values, which are used in fluid model being used (pressure, temperature etc.).
If you do not define those settings, you should have warning (or info) message in CFX-Pre output.
Actually, I did not meet this problem, while working with liquids (as I work most with gases), but this happened for me, when I started to use real gases models. There are some explanations on this topic in CFX documentation.
Dimone is offline   Reply With Quote
Old   December 31, 2010, 06:35
jarrai
Thank you for your help:
simple model, difficult outlet Eric CFX 7 May 23, 2014 08:13
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
How to achieve constant static pressure in inlet? Zou Jianfeng FLUENT 0 October 21, 2008 01:55
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 14:57
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
