How to access user defined materials when creating solid domain? |
September 25, 2013, 06:16 |
Aileen Magee
Rep Power: 12 |
I don't understand why, but when I try to create a solid domain I can not find the solid material I defined myself, however on creating a fluid domain the user defined material section appears. Can anybody tell me why this happens and how I can resolve it? Thank-you! |
September 25, 2013, 07:15 |
Rep Power: 143 |
If it does not want to show you the edit materials GUI, then define the solid using any old material and use the CCL editor to change it to the values you want.
September 26, 2013, 07:49 |
Aileen Magee
Rep Power: 12 |
Hello, thank-you for your reply. The problem is I am trying to create sodium chloride, and have to manually create sodium and chlorine then use these user defined materials to make a fixed composition solid. I have tried just changing current materials, but because I have to change it from a pure substance and then access the user defined materials it still doesn't show when trying to assign it to a domain. Is there anything else I can try?
September 26, 2013, 18:41 |
Rep Power: 143 |
The material properties you need depend on what you are going to do with the material. What are you modelling with this material?
domain, material, solid, user |
Creating new user defined material | Vidya | FLUENT | 4 | August 26, 2013 09:26 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Howto Sphere solid as a subdomain inside a domain? | jakjak | CFX | 0 | October 24, 2007 23:31 |
Really big problems when creating own materials da | Jop | FLUENT | 0 | June 28, 2007 11:15 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
