Home > Forums > Software User Forums > FLOW-3D
simulating flow in a flume
Like Tree2Likes
  • 1 Post By pyxbird
  • 1 Post By pyxbird
Old   March 6, 2013, 04:05
Default simulating flow in a flume
bird
pyxbird is on a distinguished road
Dear all,
Hi, as we can see in the piture, I am simulating flow in a 50m long water flume. The inlet velocity is about 44cm/s, the depth is 50cm. 2500 grids in x direciton is used for 50m long flume and 70 grids in z direciton is used for 70cm in height. After the flow becoming steady, I plot x-velocity in z-direction at about x=35 to 40m, and the outcome is the blue curve. However in experiment the outcome turns out to be the green curve.
So my question is, how could I improve my model?
shincoast likes this.
pyxbird is offline   Reply With Quote
Old   March 7, 2013, 03:51
Yi-Lang Chen
Andy Chen is on a distinguished road
Originally Posted by pyxbird View Post
Dear all,
Dear pyxbird :
You can try to set up "roughness height"
Andy Chen is offline   Reply With Quote
Old   March 7, 2013, 03:54
bird
Originally Posted by Andy Chen View Post
Dear pyxbird :
Where is it? And what's the value I should give to it?
Old   March 11, 2013, 04:34
Yi-Lang Chen
geometry-->component-->component properties-->surface properties-->surface roughness
you have to set up roughness height at surface roughness, and that Dimensionless is [L].
It was obviously on your results file. your geometry was too smooth so that velocity too fast at bottom.
What is material of your flume? You can set about roughness height according to your flume.
Old   March 13, 2013, 06:37
bird
I haven't added any component or material in the simulation.
You mean I should set a component at the bottom instead of using wall boundary at Zmin? I have tried to changed the friction coefficient up to -10, but it is useless.
So how about the roughness height? For example if it is glass, what shall the value of roughness height be?
Old   March 14, 2013, 02:54
Yi-Lang Chen
If you want to set surface roughness, then you have to add component. Otherwise, it doesn't work. You have to set surface roughness, not friction coefficient.
You can refer about fluid mechanics book or search roughness height [ks]. And you'll know what should you need set roughness height about glass material. Are you study hydraulic?
Old   March 18, 2013, 06:22
bird
It does work. Thank you very much, this problem has puzzled me for such a long time. Thanks a lot.
Andy Chen likes this.
Old   December 25, 2013, 02:37
miss miti is on a distinguished road
hi
I simulate flow in a flume, in analyse results the flow direction change in the middle of the flume, can anyone help me?
miss miti is offline   Reply With Quote
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Simulating a high pressure flow through a valve Kromagnsss FLUENT 8 July 2, 2010 05:20
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Simulating flow past airfoil with different AOA Quarkz Main CFD Forum 2 January 6, 2006 10:56
