Please Help me with Scheme
Old   November 29, 2011, 13:56
Default Please Help me with Scheme
TiffanyGirl
tiffanygirl is on a distinguished road
1.
Describe the worst-case asymptotic running time of the all-positive? Scheme procedure defined below (from the Exam 1 comments). You may assume that all elements of p have values below some bound k, so the running time of > is constant. Remember to clearly define all variables you use in your answer.
(define (all-positive? p)
(if (null? p)
true ; reached end without finding non-positive, so result is true
(if (> (car lst) 0)
(all-positive? (cdr lst)) ; keep looking
false))) ; found one non-positive
2.
Define a Scheme procedure make-cumulative! that takes as input a mutable list, and modifies the list so that each element is the cumulative total of all elements up to and including itself. For example,
>(define p (mlist 1 2 3 4 5))
>(make-cumulative! p)
>p
{1 3 6 10 15}
Also, what is the asymptotic running time of your make-cumulative! procedure. You should not assume the running time of the + procedure is constant; instead, assume that its running time is linear in the size (number of bits) of its inputs.
Thank you all soo much.
Love,
Tiffany xxxoooxx
tiffanygirl is offline   Reply With Quote
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 21:20
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
Definition of limiter function for central dirrerencing scheme sebastian_vogl OpenFOAM Running, Solving & CFD 0 January 5, 2009 11:08
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 11:21
