Grashof Number
Old   May 15, 2012, 06:07
Default Grashof Number
prince
prince_pahariaa is on a distinguished road
I am solving natural circulation flow in closed loop which is assisted by nitrogen injection in hot leg to increase the flow rate of coolant in the loop. Injected nitrogen is separated before the heat sink.
I am not able to decide which parameter Grashof number or Reynolds number will decide whether the flow is laminar or turbulent. Also how can i calculate two-phase grashof number ? I get a correlation to calculated Grashof number for closed loop but it for single phase (Vijyan et al 1992)
Thanks
prince_pahariaa is offline   Reply With Quote
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
Grashof Number Adrian Main CFD Forum 7 May 1, 2001 17:02
