July 1, 2010, 15:37 |
Fluent and Gambit on Windows 7?
Rep Power: 17 |
Hello
I have bought a laptop recently with Windows 7 as its Os, i wanted to install Fluent and Gambit on it but first i wanted to know: Does Fluent and Gambit work on windows 7 or not? or do they run on Windows 7 as good as they could be ran on Windows Xp? and all the features like UDF work on windows 7 too? Thanks in advance |
July 1, 2010, 17:33 |
Rep Power: 15 |
I also have windows 7, fluent and gambit work ok. for udf you will have to change environmental variables for fluent to find compiler. real problem for me was to find 64bit version of exceed. |
July 3, 2010, 08:17 |
Wirot
Rep Power: 16 |
i also agree with Alxasli , Although i set the environment, for window 7 x64 bit i can't use UDF in Fluent 12.
July 3, 2010, 21:17 |
banerji
Rep Power: 16 |
I also switched to fluent 12.1.4 , I cannot compile my UDF ..I am now reading remedies on this web:
http://www.cfd-online.com/Wiki/Fluent_FAQ#How_can_I_manage_to_compile_my_UDF_with _Windows_7_64bit.3F let me know whether you succeded |
July 4, 2010, 10:39 |
Rep Power: 16 |
Yes. Gambit and Fluent are absolutely fine with windows 7.
July 4, 2010, 22:25 |
Jemyung Cha
Rep Power: 16 |
July 5, 2010, 02:22 |
Svetlin Filipov
Rep Power: 17 |
My experience: Gambit and Fluent 6.X are working with no problem on Win 7 64X.... For Fluent 12.X.... it is up to ANSYS instalation... and yes.. you need some hand work to do....
July 20, 2010, 16:21 |
banerji
Rep Power: 16 |
Dr been if you have not been able to use your UDF in Fluent 12 ..I also struggled with it when I switched from fuent 6. I realised that even if MS visual studio is okay and enviroment set correctly..there are other windows files that work with MSVS in the compilation procedure. My issue was that MS windows SDKs were old for MSVS to work. so use the error you get and read the remedies online.
November 22, 2010, 08:14 |
#9 |
kartik
Rep Power: 15 |
hi,i have installed fluent and gambit on windows 7,though fluent is working but gambit is not and a certain message is shown on the screen when i press run.plz help me
April 2, 2012, 08:21 |
#10 | |
reza
have the -win 7 OS- intalled on my pc. by pressing the run button, shows a "Fatal Error" message telling "All XServer Displayers are in use, Exceed can not tun without a Display, Please try again at a later time." & i don know how to solve this... |
April 19, 2012, 00:08 |
#11 | |
SIVALINGAM
Rep Power: 16 |
which version of fluent and gambit you have, since in my system of same windows7 and 64 bit it does not working. |
April 19, 2012, 01:04 |
#12 | |
Lucky
Rep Power: 66 |
I have not used it in awhile but I did have Gambit 2.4.6 (32bit version) running before. I believe that it was the last released version of Gambit for Windows OS. There were a few versions after for linux/unix. Could be wrong, it's been awhile. I've been able to use all recent versions of fluent on Windows 7, v11,v12,v13,v14. Haven't tried Fluent6, since the last time I used that was on XP & Vista, and there's no motivation to test it. |
July 10, 2012, 10:42 |
Gambit
#13 |
I have ANSYS 14.0 on my system(win7 64x), and I need Gambit.
Does it need independent installation for Gambit or it included in my ANSYS? If I need Gambit, how I can get it? |
Converting Fluent mesh files to Gambit neutral files | samuelkc | ANSYS Meshing & Geometry | 9 | April 21, 2021 06:28 |
Fluent 6.2 & Gambit on Windows XP x64 | AcoidanBM | FLUENT | 9 | October 30, 2011 14:08 |
Facing Few Problems in Fluent and Gambit | Ravi Duggirala | FLUENT | 5 | March 11, 2006 03:13 |
test cases for Fluent and Gambit | Ben | FLUENT | 1 | May 21, 2003 06:44 |
2D geometry Gambit 2.0.6 to Fluent 6 | Bo Jensen | FLUENT | 1 | January 17, 2003 09:55 |
