the different result with different Amush
Like Tree3Likes
  • 3 Post By sooroo3
Old   August 13, 2012, 04:37
Smile the different result with different Amush
Fangdian
fangdian is on a distinguished road
Hi
I use the VOF & solidfication and melting model these days. When I set the mushy zone constant Amush, I found it has different results with different Amush(the recomended value is 1e4~1e7) .
My problem like this :
A briquette steel lays on the bottom of a case with idea air. the solidus and liquidus temperature is set to 177K and 1793k. The pure solvent melting heat is 270e3J/kg.
there is no any heat soure in the system, and the system is initialized with room temperature 300K.
With small Amush ,1e4 for example, why the steel deform with enough time ?
With differnt Amush, the deformation of steel is differnt. The bigger Amush, the little more time needed with deformation.
WHy?
thanks!
fangdian is offline   Reply With Quote
Old   November 26, 2012, 08:25
YG Kim
sooroo3 is on a distinguished road
I also did works by use of VOF & melting model in Fluent. Amush(morphology constant) looks like constant, but it has kg/(ms) as unit. As I know, Voller tested solidification behavior with variable Amush. By the way, when we look at Voller's or related papers, it is more easy to figure out what Amush is. As can be seen, it has same unit with dynamic viscosity. Thus, somehow we can image it as like draging. Increasing Amush, flow in mushy zone is quite tough to pass through it like dense liquid which pass through porous nozzle. Hope it help a bit.
ghost82, MrDaimon and jyothsna k like this.
sooroo3 is offline   Reply With Quote
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 10:27
How to display the whole result of a periodic model via one period result? dixylo FLUENT 2 February 23, 2012 04:11
Read Result Files or User Defined Result Aquilaris ANSYS 0 February 9, 2011 05:25
In a distance above the ground, my LES result is not good panda60 OpenFOAM 2 January 22, 2010 07:52
LES result harrislcy FLUENT 1 December 28, 2009 06:29
