How to display an isometric view in batch mode
Old   August 16, 2012, 15:20
Default How to display an isometric view in batch mode
Guiliguili
Touré is on a distinguished road
I want to display the isometric view in batch mode.
When I run this part of the journal below in interactive mode, it works, but it doesn’t work in batch mode. Someone knows why?
My journal is below:
; Define Planes
; x0 y0 z0 ix iy iz
/surface/plane-point-n-normal plane_y-z -0.06 0.275 0.006 1 0 0
/surface/plane-point-n-normal plane_sym_x-z -0.06 0.275 0.006 0 1 0
/surface/plane-point-n-normal plane_x-y -0.06 0.275 0.006 0 0 1
; Set Color-Map Alignment Right
/display/set/rendering-options/color-map-alignment right
; Set Window for plane_sym_x-z plane velocity magnitude
/display/set-window 6
/display/set/contours/surfaces plane_sym_x-z ()
/display/set/contours/n-contour 30
/display/set/contours/global-range n
/display/set/contours/clip-to-range y
/display/set/contours/filled-contours y
/display/contour/velocity-magnitude 0 10
; Set View
/display/views/restore-view isometric
; Animate Plane
/solve/animate/define/define-monitor "velocity_magnitude" 6 n y 10 contour hmf ""
The error message invalid command is below:
> adapt/ file/ report/
define/ mesh/ solve/
display/ parallel/ surface/
exit plot/ views/
> Alignement: (left right top bottom)
exit plot/ views/
> invalid command [isometric]
I need some help.
Touré is offline   Reply With Quote
Old   August 18, 2012, 21:10
Default Solved
Guiliguili
I had a problem with graphics on the cluster
My command line was:
fluent 3ddp -ssh -t8 -g -i < fluent_case.jou > fluent_case.out
I change it to:
My command line is:
fluent 3ddp -ssh -t8 -gu -i < fluent_case.jou > fluent_case.out
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 1 October 18, 2017 12:11
to run a replayfile in batch mode from UNIX froztbear ANSYS Meshing & Geometry 4 May 13, 2014 08:00
cfdpost in batch mode taichijulie CFX 1 October 25, 2010 15:29
DPM model in parallel batch mode Prashanth FLUENT 2 March 6, 2009 07:54
Prosurf in batch mode Dhruv Siemens 1 September 19, 2005 18:02
