Urgent; parallel processing in fluent 12
Old   December 27, 2010, 02:09
Unhappy Urgent; parallel processing in fluent 12
Mansureh is on a distinguished road
Hello every body
I want to do parallel processing in Fluent 12, but when I launch fluent 12 and choose parallel option, Fluent gives following error:
Loading "D:\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\li b\flprim1119.dmp"
Done.
Host spawning Node 0 on machine "chemeng-db7ca10" (win64).
999999: mpt_get_dot_address: warning: chemeng-db7ca10 -> 127.0.0.1. Check your system network configuration!
You can press CTRL+C to stop the startup process!
WARNING: No cached password or password provided.
use '-pass' or '-cache' to provide password
mpid: Cannot connect to mpirun (0.0.0.0, 1126): Unknown error
connect_mpirun failed
What should I do?
thanks for any help
Mansureh is offline   Reply With Quote
Old   January 18, 2011, 07:51
NeNaD
skinnyfluid is on a distinguished road
Mansureh,
which Number of Processes you setup?
skinnyfluid is offline   Reply With Quote
Old   September 24, 2012, 04:26
Default i got the same problem
zdong
abbott.hn is on a distinguished road
Originally Posted by Mansureh View Post
Hello every body
Done.
What should I do?
thanks for any help
i have got the same problem, some guys said that this would be ok if i plug in the network line ,but what's the real reason ? should ansys fluent work at internet enviroment?
abbott.hn is offline   Reply With Quote
Old   September 24, 2012, 08:03
SANDRA BENVENUTO
mashiro is on a distinguished road
turn off your fire wall.
mashiro is offline   Reply With Quote
Old   September 25, 2012, 11:12
shoeb khan
shk12345 is on a distinguished road
Try to make a server machine and the other clients machines and then connect them in a lan.
Then install fluent om the server and install mpinch client on the client.
Then try to run it
Hope that will work.
shk12345 is offline   Reply With Quote
parallel processing Fluent 6.3.26 ck3 FLUENT 6 October 30, 2013 00:44
Parallel Processing on ANSYS FLUENT 12 srr FLUENT 2 April 16, 2011 14:16
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 10:11
Fluent Parallel Processing Mrxlazuardin FLUENT 2 April 28, 2010 07:36
Parallel Fluent with Mandrake Daniel Dotta FLUENT 1 May 19, 2005 15:30
