Is diffusion is possible through VOF model of Fluent?
Like Tree1Likes
  • 1 Post By coglione
Old   October 10, 2012, 03:31
Question Is diffusion is possible through VOF model of Fluent?
Blue's Avatar
Blue is on a distinguished road
I have to simulate intermixing phenomenon inside a tank. Tank is a rectangular in shape have one inlet at top and three outlets at bottom. Tank has particular quantity of water inside. Concentrated water (tracer) is coming through inlet and after mixing in tank water+tracer is coming out through bottom outlets. Due to inflow rate, free surface height of tank is increasing. I have to monitor tracer concentration and free surface height of water inside tank. My questions (a) VOF model is for immiscible fluids, so is it possible to diffusion or mixing of water and tracer(concentrated water) if this model is not appropriate then which model I should use which have mixing and free surface height calculation.
Thank you
Blue is offline   Reply With Quote
Old   October 10, 2012, 04:21
Max
coglione is on a distinguished road
You may define your liquid phase as mixture of two components (h2o & tracer). Patch zero initial massfraction for tracer, set a non-zero massfraction for tracer at your inlet and record the concentration in the mixing device over time.
cheers
Blue likes this.
coglione is offline   Reply With Quote
Old   October 10, 2012, 05:40
Blue's Avatar
Thank you very much..can u explain more..
fluent, free surface flow, vof
Patching Second Phase Region in Fluent V13 VOF Model sda FLUENT 19 July 3, 2022 06:00
Evaporation model in ansys Fluent 12.1 oldisbest Fluent UDF and Scheme Programming 12 March 26, 2020 09:11
question about Heat transfer between two phases with VOF model sooroo3 FLUENT 0 February 15, 2011 03:24
Doubts UDS Flux, UDS Unsteady for VOF model kel85uk FLUENT 0 March 17, 2010 08:53
Reynolds Stress Model in Fluent Vs CFX Tim FLUENT 0 December 6, 2005 22:03
