Gasification modelling using non-premixed combustion
Old   November 12, 2012, 03:57
Default Gasification modelling using non-premixed combustion
Nurul
nurul efha is on a distinguished road
Hello everybody,
I'm simulating gasification using Non-Premixed Combustion and DPM. In this forum, I want to ask about my problem.
First, the char conversion 24% (is very low). Do you have any suggestion to get higher conversion by using non-premixed combustion?
I've been simulated this by laminar finite rate model in same test condition (T=367K; P=1atm;Size particle = 25 micrometer; loading factor = 0.933 kg coal/kg gas) and char conversion 99.99%.
Second, can we use wet combustion in Non-Premixed Combustion?
Then, am I right if I think that liquid in wet combustion means water added (not moisture content of coal)?
If I want to inject steam to gasifier, what should I set?
Hopefully your answer. Thanks.
nurul efha is offline   Reply With Quote
dpm, non premixed combustion, wet combustion
Modelling of premixed combustion in a burner rig ThomasS FLUENT 12 September 7, 2018 13:07
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
Nonpremixed Combustion Model for Coal Gasification C.Y.Ler FLUENT 2 April 29, 2014 08:51
Gasification modelling using non-premixed combustion nurul efha Main CFD Forum 0 November 8, 2012 04:08
Partially Premixed Combustion - Direct Fired Boiler oknus FLUENT 0 April 10, 2012 10:52
