initializing part of problem from previous solution..help!!!!
Old   April 23, 2014, 06:50
Default initializing part of problem from previous solution..help!!!!
Virendrasingh Pawar
virendra_p is on a distinguished road
hi friends,
this is very important for my thesis completion....please help me out!
i am implementing VOF method for standard pump-sump setup..i have realized single phase solution and i want to use this solution for intializing VOF setup.
is this possible in fluent? any suggestions
p.s. the domain for VOF setup is extended (addtional air doamian is constructed) so mesh sizes is different than the 1 phase setup
virendra_p is offline   Reply With Quote
Old   April 23, 2014, 08:07
praveen@cfd-online.com's Avatar
Praveen Kumar R
praveen@cfd-online.com is on a distinguished road
Hi Virendrasingh,
Yes it is possible to use the results of an earlier simulation (different mesh) as an initial value to the current simulation.
Follow below steps:
  • Open previous case and data file in FLUENT
  • File ----> Interpolate -----> Write Data
  • Select the variables you want to use in new simulation, from the fields
  • Save the interpolation file
  • Open new case and data(initialized for air domain) file in FLUENT
  • File -----> Read and Interpolate ---> Read
  • Open the saved interpolation file
This should Work. All the Best!!!
Best Regards,
Praveen
praveen@cfd-online.com is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Numerical Solution of the Blunt Body in Supersonic Flow Problem andres17 Main CFD Forum 19 April 26, 2016 15:29
Initialization using previous solution data for similar (not the same) grid sercan85 FLUENT 0 August 31, 2012 07:38
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
Problem with hypersonic blunt cone solution Bharath Hebbal FLUENT 0 February 15, 2008 02:07
