Contours of Velocity Magnitude
Old   February 10, 2010, 11:15
Default Contours of Velocity Magnitude
sed
cfdiscool is on a distinguished road
Hi
What exactly will be reported by FLUENTS
display----> Contours--->Velocity--->Velocity-Magnitude...
Is it the sum of all the three velocity(x,y,z) components?......
what if the flow is only in one direction say Y and X=0 and Z=0 ? What exactly is then reported my Velocity Magnitude
thank you
nice day
Life is not always converging ... but u can relax
cfdiscool is offline   Reply With Quote
Old   February 11, 2010, 01:20
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Velocity Magnitude = sqrt (Ux**2 + Uy**2 + Uz**2)
If Uy=Uz=0, then VM = sqrt(Ux**2)=Ux
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 11, 2010, 05:13
sed
thank you max
this explanation is very clear.....
i can see Ux Uy Uz (X-Velocity,Y-Velocity etc...) distinctly .......i mean i can visualize these three components clearly with various contour levels and find velocity variations in my domain.......but when I switch to "Velocity Magnitude" in contour display option ...most of my domain shows deep blue color which is close or equal to 0 m/s......
Does this mean that i do not have any resultant velocity at the end? or doest it mean the resultant velocity is a result of your explanation above.....
Old   February 12, 2010, 01:15
-mAx-'s Avatar
Maxime Perelli
you should have a place with high velocity in comparison with all your domain. Modify the scale of the VM
Old   December 20, 2012, 12:39
Osamah Ali Al-Hashimi
Al-Hashimi is on a distinguished road
What is ment by Modify the scale of velocity magnitude? do you kindlly mean to change the velocity to a higher value? whats if the velocity is an inlet velocity boundary condition?
Al-Hashimi is offline   Reply With Quote
Old   January 3, 2013, 01:14
-mAx-'s Avatar
Maxime Perelli
I meant: modify upper scale limit (max value)
contour plots, display, magnitude, velocity
formula for velocity magnitude Hai Duc FLUENT 0 January 9, 2008 07:39
velocity magnitude contours gh FLUENT 7 June 7, 2005 09:27
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
