How can I place the slab inside the furnace?
Old   January 15, 2013, 11:12
Question How can I place the slab inside the furnace?
Tiago Morgado
TMorgado is on a distinguished road
I want to simulate a transient heat transfer of metal slab inside a re-heating furnace, but I want to do this starting from a converged steady-state simulation of an empty furnace.
How can I place the slab ( a solid cell zone ) inside the empty furnace (a fluid cell zone domain) after finishing the converged steady-state simulation?
Thanks in advance
TMorgado is offline   Reply With Quote
Old   January 15, 2013, 13:56
cfd seeker is on a distinguished road
You will place that slab in the cad or meshing software and then regenerate the mesh with slab inside the furnace but in fluent i guess you can't use the results of only furnace as the initial conditions for furnace+slab case.
But one other thing you can do....generate the mesh of furnace+slab case and first set the slab as "adiabatic wall" the default option in fluent and get the results. Then set the slab as "convective wall" and use the results of "adiabatic wall" as the initial conditions.
cfd seeker is offline   Reply With Quote
cell zones, furnace, transient conduction
Simulate transient heating of a slab in a furnace TMorgado Fluent UDF and Scheme Programming 0 December 6, 2012 18:41
Skipping zone inlet (not referenced by grid) vinoo FLUENT 7 February 18, 2010 19:05
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Heating of a metal piece inside a furnace CFDguy FLUENT 2 September 5, 2008 08:41
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
