Wind tunnel corner vanes, loss coefficient
Old   February 8, 2013, 17:41
Default Wind tunnel corner vanes, loss coefficient
SydBarrett11 is on a distinguished road
Hi guys,
sorry for quite a silly and long question.
Recently, I have solved an 90° elbow, with corner vanes in it, and I would like to get a loss coefficient of that elbow.
inlet: velociy inlet, outlet: outflow, walls: with roughness specified
Loss coeficient is defined as K=(p_in-p_out)/dynamic_presure
How do I get the pressure drop? So should I substract outlet pressure value from inlet pressure value? Static or total? Is that so simple?
static pressure in= -23Pa
total pressure in = 792Pa
static pressure out = -149Pa
total pressure out = 667Pa
Pressure drop in both cases (static and total) 126Pa??? Is that right? (are these values the same, only because the velocity throught vanes almost didn't change?)
A what about operating pressure? Is it important when counting pressure drop? I set operation pressure 101325Pa a placed its coordinates out of geometry, but when I change the coordinates, pressure values changes but the difference remains the same.
Thanks
SydBarrett11 is offline   Reply With Quote
Wind tunnel lift coefficient DoHander Main CFD Forum 2 August 13, 2010 09:28
how to consider perforated wind tunnel wall in CFD simulation littlelz CFX 4 June 11, 2009 05:51
Wind Tunnel Testing Francesco Nicolosi Main CFD Forum 0 November 25, 2008 12:55
Virtual Wind Tunnel in FLUENT ND FLUENT 0 April 7, 2006 07:43
Wind tunnel modeling Pandu CFX 3 May 19, 2003 21:49
