problem with bodies transferred from the mesher |
February 21, 2013, 20:47 |
yahya
Rep Power: 13 |
I built a huge model using designmodeler that consist of more than 300 bodies, and then I did my mesh using meshing application available in ANSYS 14, in addition, I have created a named selection for several faces and bodies.
However, when i transfer it to fluent all the bodies is transferred by itself, i.e. like if I have 250 bodies as interior each one is transferred by itself and i need to specify it as interior 250 time in the boundary conditions box in fluent, in addition, for the named selections if I selected 10 faces as walls, when I transfer it to fluent each one is transferred by itself as wall (not all as package). So in summary, i need when I transfer the model to be transferred as one package for interior and one package for each named selection, because this problem take long time to upload the geometry. best regards, Yahya |
February 27, 2013, 13:35 |
DM
sp
Rep Power: 14 |
Did you combine all these bodies into one 'part' in Design Modeler before meshing? If not, you should - unless you plan to have a sliding interface type situation.
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
