Dynamic mesh procedure for gear pump
Old   May 2, 2013, 07:44
Default Dynamic mesh procedure for gear pump
mahendra
mrdumpa is on a distinguished road
Hi All,
I facing problem while working with 3d gear pump.
1. My problem is i want to run my model in FLuent using dynamic mesh
option by rotating two gear with same RPM.
2. I have written UDF for both to rotate with 1000rpm in opp direction.
But i am facing problem in setup the options in Dynamic mesh panel.
ie. smooting,layering and remeshing options setup for this problem
Can anyone help me how to setup options in Dynamic mesh Panel
Please find the attached picture of model.
mrdumpa is offline   Reply With Quote
Old   June 10, 2013, 17:21
Arthur Loginow
Maralady is on a distinguished road
Hello, I am working on something similar, a twin screw pump, would you like to share emails to exchanges information?
Maralady is offline   Reply With Quote
Old   June 10, 2013, 23:44
sina
sina.sh is on a distinguished road
Dear Mahendra
You can use Sliding Mesh for this case. But if you want use dynamic mesh, remeshing is best choice. Remember that moving mesh is very expencive method. Plz see fluent tutorials.
Best Regards
sina.sh is offline   Reply With Quote
Old   June 14, 2013, 10:34
delaneyluke is on a distinguished road
The 2.5D remesh option is perfect for the case you're solving.
It only remeshes the top surface and then drags the cells down to form the 3D mesh. You need to mesh your domain with prism cells for it to work. Let me know if you have any more questions
Regards
Luke
delaneyluke is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
potentialFreeSurfaceFoam with Dynamic Mesh GuilhermeMP OpenFOAM Programming & Development 1 October 6, 2013 03:05
Dynamic mesh in Fluent to study tire in contact with road surface lihuang FLUENT 10 March 8, 2011 10:21
Dynamic mesh - structured mesh mrestrepo30 FLUENT 0 June 3, 2009 15:40
