Fluent init-instantaneous-vel command, DES
Old   August 16, 2013, 11:07
Question Fluent init-instantaneous-vel command, DES
Sheng
micro11sl is on a distinguished road
Dear all,
I have 3 questions not clearly understood.
1. As we can see from Fluent's guide for LES, if we continue from a steady RANS result, we must type the command "init-instantaneous-vel" to obtain an instantaneous velocity field. Question: does this apply to DES calculation? And, this option is not available for SA model?
2. What Fluent exactly does when we type "init-instantaneous-vel"? Can anyone render some hints? What's the formula or function?
3. I have one more question regarding the DDES model using SST turbulence model.
We know there're 4 options we can choose for SST-DDES in Fluent: F1 function, F2-function, DDES and IDDES. The user manual gives exact information about the F1 and F2 function based formulation. Question: what the exact formulation of the DDES and IDDES option? The user's manual just says it uses the same idea of SA-DDES, IDDES, with a constant changing from 8 to 20. Is there anyone know more about this?
Regards,
Sheng
micro11sl is offline   Reply With Quote
Old   August 26, 2013, 04:47
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Dear Sheng,
1) the option is always available, i don't remember if you first have to switch to unsteady and/or LES (which imply unsteady nonetheless) but then you can definitely switch again to any other model and, OF COURSE, Fluent can't drop off your actual data. Just give it a try
2) The method is the same as the spectral sinthesizer used for the inlet (check the manual). The difference is that no time variable is involved and, possibly, different constants are used
3) I'm not that much into DES and related methods. You should check some relevant reference
sbaffini is offline   Reply With Quote
Old   August 26, 2013, 06:48
Sheng
Originally Posted by sbaffini View Post
Dear Sheng,
Thanks very much for the reply by sbaffini.
1) I tried and have got some data by far. I found under S-A model, there is no "solve/init/init-instantaneous-vel" command available, although from the user manual, it is stated the command is available for ALL RANS turbulence models.
2) I will investigate your reply further. It's interesting.
3) I look around some papers and have got some ideas. I will post my findings later.
I have a further question to ask sbaffini: do you use LES often more than DES?
Old   August 26, 2013, 07:24
sbaffini's Avatar
Paolo Lampitella
Dear Sheng,
the main reason for the limitation you are facing may be due to the fact that, if i remember correctly, the method requires a velocity and a length scale to be specified in the domain to properly work. SA instead only provide one single scalar which is a combination of both. If you really need to use SA then you could try the following:
1) Once the solution with SA is obtained switch to k-eps; if the eddy viscosity is preserved go further (otherwise there is no chance)
2) Write a DEFINE_INIT UDF which will do the following:
- copy the velocity (and maybe pressure) as they are, i.e., with C_U(c,t)=C_U(c,t)
- for each cell define your own length scale L. This is somewhat arbitrary, but it is the only option. You might want to use some blending between the wall_distance and the local cell spacing (cubic root of cell volume). Take also a look at the DES,DDES descriptions for some other relevant definitions; still, neither of them will actually give you a proper length scale as required by the method for the initialization.
- with the eddy viscosity (NU_T(c,t) if i remember correctly) and the length scale above you can initialize the k and eps variables trough the proper definitions which should also be available in the Fluent manual.
3) Use such a UDF to initialize the flow
4) If everything worked correctly, you should now be able to use the initializer with some fields which are at least partially significant. The definition of the length scale might be strongly affecting the initialization process.
I never used DES and i almost exclusively work in LES
Old   August 26, 2013, 07:36
Sheng
Dear Sheng,
Thanks for a prompt reply.
That's what I am wondering. I wonder that step "init-instantaneous-vel" is not essential for DES simulation and inlet boundary condition doesn't require unsteady velocity fluctuations. IDDES may be different. I will investigate this further.
Connecting Fluent benefits and Injection Molding Software Jim87 FLUENT 1 August 6, 2023 16:06
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
