Repeating Error Message
Old   March 7, 2017, 15:42
Default Repeating Error Message
Luke Brawley
brawleyl is on a distinguished road
I am attempting to set up a simple 2D geometry to model an oscillating flat plate with the goal being to look at the boundary layer fluctuation. I have created a UDF to control the oscillating velocity as a function of time. After setting up the geometry, mesh, and solution method I run the problem then go to open the results. Every time I try to open the results I get the error message "ERROR: 'wbload' action requires parameter: 'id'."
I have been trying all day to resolve this error and I am no closer to figuring it out. The only reference I could find on this forum was from 5 years ago and said that it happened if there were special characters in the name of your project which is not true in my case. A friend of mine is running a similar problem and gets no error messages. Even when I switch every one of my conditions to be the same as his I still get the same error message. Does anyone have any idea what could cause this error?
brawleyl is offline   Reply With Quote
Old   March 7, 2017, 16:00
Luke Brawley
This error has been resolved. A folder that was farther back in the directory path had a pound sign in it but none in the active folder which is why I didn't find it immediately.
Substitution of repeating geometry to simplify akay ANSYS 0 December 9, 2014 14:34
Cyclic BC for repeating geometries Yeru OpenFOAM Programming & Development 4 July 3, 2014 09:50
Sliding Mesh/ Repeating interface apc3161 STAR-CCM+ 0 September 4, 2009 19:31
Repeating same time steps (FSI) CJ Tune Siemens 0 February 25, 2003 20:27
Repeating same time steps (FSI). cjtune Siemens 0 February 19, 2003 23:05
