How to set the "inlet" for surface reaction ? |
January 17, 2014, 11:19 |
Dziyad Dzulfansyah
Rep Power: 12 |
hi..
my name is Dziyad. I will do research about CFD analysis for biomass gasification. I will use particle surface reaction. i will use c(s) as particle, but i have problem about how to set the inlet for surface reaction. Would you like to give me some suggestions. Thank you very much |
January 18, 2014, 10:11 |
addition to your query
Anand M Shivapuji
Hi, I am also initiating work on gasification and towards the same I am working out with single particle analysis. I wanted to know how did you define the solid particle? I mean if suppose we have a sphere then do you treat the sphere as a wall or is there a different philosophy altogether?
Thanks in advance |
January 19, 2014, 02:43 |
Dziyad Dzulfansyah
Rep Power: 12 |
i define the solid particle as combusting material using Discrete Phase Model. But when i iterate it, there is no combustion occur. i can't solve it yet
November 5, 2014, 11:27 |
#4 | |
Rep Power: 12 |
Please have you been able to rectify this problem where no reaction occurs when particle surface reaction is selected in Fluent |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Install Openfoam in Suse 100 setup environment | h34gk1 | OpenFOAM Installation | 1 | September 26, 2006 20:08 |
Problem installing on 64bit with ver13 | jonititan | OpenFOAM Installation | 5 | May 12, 2006 18:42 |
Problem installing on 64bit with ver13 | jonititan | OpenFOAM Installation | 0 | April 28, 2006 05:45 |
How to set environment variables | kanishka | OpenFOAM Installation | 1 | September 4, 2005 10:15 |
