solid rocket combustion
Old   February 24, 2013, 16:13
Unhappy solid rocket combustion
sadane
nadjibe is on a distinguished road
hi every body, i want to simulate solid rocket combustion but i dnt know any thing, help me please, should work whith ansys fluent? wich model of combustion.......,mesh.... help me please
nadjibe is offline   Reply With Quote
Old   February 24, 2013, 21:59
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
tutorial on how to mesh and how to perform simulation are included in fluent.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   February 26, 2013, 00:41
Default combustion du propergols solide
sadane
merci ali je vais voire tutoriel, c tres gentil
Old   February 26, 2013, 14:30
Default rocket combustion modeling
sadane
salut ali, pouvez vous me donner votre adresse email car j'ai quelque questions a poser sur la combustion? merci pour votre aide.
Old   April 29, 2013, 14:51
Unhappy dear ali
sadane
hi ali how r u? i want please how i can modeler the propellant combustion please
Old   April 29, 2013, 14:59
diamondx's Avatar
Ghazlani M. Ali
what's a propellant combustiion ??
Regards,
Ali
Old   April 29, 2013, 15:26
Default hi ali
sadane
the rocket solid propellant ammonum perchlorat with binder HTPB OR PVC OR PMMA, and miniral ingrediants. first what is the model in ansys must be used? what about the pyrolisis model solid gaz?, boundry conditions? turbulence...
Old   April 29, 2013, 15:33
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hey
I can tell you that it's a very big headache. That's it.
Regard yours
A CFD free user is offline   Reply With Quote
Old   April 29, 2013, 15:44
Default thank's
sadane
thank's for all
Old   April 29, 2013, 15:45
diamondx's Avatar
Ghazlani M. Ali
i've never done solid combustion. not sure i can help you with it. use the search option in the forum
Regards,
Ali
Old   April 29, 2013, 17:03
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I have worked on solid rocket propulsion using Fluent when I was co-supervising MS project.
There are many problems that need to be addressed:
1. There is no inlet
2. solid particle get eroded due to combustion and depleted at different rates from different surfaces of fuel and that must be included in simulation
3.The first change to liquid and ultimately to gaseous phase. So all these phases must be modeled. How? I don't know.
4. The combustion models in Fluent assumes fuel to be gas or in liquid phase and no option for solid.
In short you may be required to implement your own model in Fluent, which somebody added for their research at some US lab, but it is not available in open literature.
Far is offline   Reply With Quote
Old   May 2, 2013, 13:38
Default thank's
  #12
sadane
thank you ( no inlet????)
Old   May 2, 2013, 15:10
Far
Sijal
Well we thought that once combustion is started (no fuel is injected, every thing is inside) , so there is no inlet. What do you think?
Old   May 3, 2013, 02:52
Default hi ahmed
  #14
sadane
i m agree whith u but the problem in balance equations how can i do?
Old   March 3, 2014, 07:23
Guy
kookguy is on a distinguished road
I guess, if you are just modelling thrust and instability, knowing an approximate regression rate, you might be able to simulate the solid propellant using the product of combustion in the liquid/gaseous form. (Or premix air/fuel and inject radially along the propellant surface).
My question is how would you specify the fuel species in fluent. I am really new to this program.
kookguy is offline   Reply With Quote
Solid combustion problem.... godspeedsam FLUENT 3 May 24, 2022 04:29
combustion of solid rocket propellant sunitadeb89@yahoo.co.in FLUENT 0 October 14, 2012 17:04
solid rocket combustion ssixr FLUENT 0 June 18, 2010 22:50
Rocket Combustion Aralati FloEFD, FloWorks & FloTHERM 0 March 13, 2010 21:42
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
