Error: No graphics functions are available. Error Object: () |
June 12, 2014, 12:05 |
Rep Power: 12 |
I am having problems running my transient simulation of a bluff body with fluent in batch mode. An error message stated below comes up. Error: No graphics functions are available. Error Object: () My journal file script reads like this; ; Read case and data files file read-case-data Rc_transient.cas solve/set/time-step 2.0e-4 solve/dual-time-iterate 100 20 Exit |
August 20, 2015, 05:21 |
#2 | |
Mina
Rep Power: 10 |
hi
did you solve it? I have the same error! Quote:
August 20, 2015, 12:24 |
Lucky
Rep Power: 66 |
I think Fluent is trying to output graphics to the screen (probably the residual plot or monitor plots), but no graphics processor is available. Make sure you are running fluent without a gui (-nogui mode) or manually remove all graphics in your setup.
August 21, 2015, 02:41 |
Mina
Rep Power: 10 |
thanks for replying. when I run it in HPC this error occured.Otherwise in my computer it runs and draw the residual graph.But I cannot continue running it with that.it may takes several weeks. Doyou think it is a problemm of parallel solving or some thing like this? If yes why it doesnt happen to other colleagues! |
August 21, 2015, 23:52 |
Lucky
Rep Power: 66 |
Did you run in -nogui? i.e. 3ddp -nogui
August 24, 2015, 02:43 |
Mina
Rep Power: 10 |
August 24, 2015, 08:45 |
Lucky
Rep Power: 66 |
Then try <2ddp -nogui>
you must enter -nogui or else Fluent will think there is a GUI available and will try to output graphics. By entering -nogui, Fluent skips all graphics outputs even if you have them setup, like plots for monitors, etc. |
November 30, 2017, 00:50 |
#8 | |
yesenia
Rep Power: 11 |
<fluent 3ddp -nogui> Thanks, Yesenia |
August 23, 2018, 05:00 |
#9 |
Feiyu
Rep Power: 10 |
you should include graphics when launching Fluent by adding '-gu' instead of '-g'. This solved my problem.
February 6, 2020, 00:44 |
#10 | |
wangqiaowei
Rep Power: 6 |
the slurm is as followed export FLUENT_GUI=off /lustre/home/acct-ccelm/ccelm/wqw/linxi-fluent17.2/ansys172/ansys_inc/v172/fluent/bin/fluent 3ddp -t200 -g -i a135.jou -r17.2.0 -pib I use GUI off, but in error file Error: No graphics functions are available. Error Object: () Error: Case is not valid. Error Object: #f slurmstepd: error: *** JOB 320220 ON cas025 CANCELLED AT 2020-02-06T12:33:17 *** |
February 6, 2020, 05:13 |
Could be due to animation or commands
#11 |
This is also possible due to problems, such as, you have any commands given to setup an animation, or plot is enabled for any of the monitors. Check that only print or write is enabled for monitors and not plot.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 6, 2020, 07:01 |
thank you for the advise!
#12 |
wangqiaowei
Rep Power: 6 |
thank you for the advise! I found report file on just now, finally the problem is solved. Thanks!
February 6, 2020, 07:14 |
Good
#13 |
Nice to know.
December 21, 2022, 07:26 |
solved
#14 |
Xilin Wang
December 21, 2022, 07:46 |
#15 |
wangqiaowei
Rep Power: 6 |
[Commercial meshers] CCM+ Mesh Conversion | Ingenieur | OpenFOAM Meshing & Mesh Conversion | 17 | February 2, 2014 09:34 |
Delta Functions within Ansys Mechanical | Stephen Waite | Structural Mechanics | 2 | July 29, 2013 08:56 |
field functions - table | crevoise | STAR-CCM+ | 3 | March 26, 2013 09:37 |
Field functions and table | crevoise | Siemens | 0 | March 20, 2013 10:51 |
User-Defined Functions | Boisson | FLUENT | 2 | January 18, 2002 22:09 |
