March 9, 2015, 07:41 |
Coefficient of lift on a tidal turbine blade
Rep Power: 11 |
Hi I'm struggling to find the coefficient of lift on the airfoil im simulating in underwater conditions. The only change I can see to make is the density of water surrounding the airfoil but when changing this, this makes the output coefficient off by this factor. Is this correct? I can't believe it is, and struggling for accurate results. Any help would be appreciated.
Thanks |
airfoil 2d, airfoil analysis, coefficient of lift, fluent 14 to fluent 15. |
Problemwith lift coefficient - tidal turbine | stokesy | FLUENT | 2 | March 6, 2015 03:54 |
increase the lift force for wind turbine blade | dipaksutradhar | OpenFOAM Running, Solving & CFD | 0 | January 28, 2015 15:14 |
Calculating lift force of a wind turbine blade problem | LittleBart | CFX | 4 | June 29, 2011 02:33 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
Lift coefficient Plot for turbine blade- Reg | Mahendran.M | FLUENT | 2 | June 19, 2006 22:43 |
