Low Massflow Inlet causes no convergence
Like Tree1Likes
  • 1 Post By CFD_Flo
Old   July 16, 2020, 09:01
Default Low Massflow Inlet causes no convergence
CFD_Flo is on a distinguished road
I am new to this Forum and have a question about my simulation. I am simulating a multi-species flow through a channel. The Mass-Flow at the inlet is pretty low (about 10^-5 kg/s) and the two species are both liquid. One species enters the domain at the massflow inlet and the other is initally everywhre in the domain. The outlet is a pressure outlet. The solution doesn't converge and the temperatures are getting high (about 10^3 K). When I increase the mass-flow, everything works fine. Do you have any advices for me?
Thank you!
CFD_Flo is offline   Reply With Quote
Old   July 16, 2020, 14:00
Guvennergiz's Avatar
Guven Nergiz
Guvennergiz is on a distinguished road
Hi Flo,
If you're solving incompressible flows, can you try velocity-inlet instead of mass-flow-inlet?
I would also like to remind you for control purposes only; If there is an initial temperature in the main fluid (host), you should define it by patch.
I hope that these can fix your problem.
Best regards,
Güven
Guvennergiz is offline   Reply With Quote
Old   July 17, 2020, 03:29
Hi Güven,
thanks for your answer. I am simulating a compressible flow and i found a solution! I refined the mesh in flow direction and it worked. I was just confused by the fact, that higher massflows converged.
Best regards
Flo
Guvennergiz likes this.
Low Mach number wing/body junction convergence Zen SU2 6 May 3, 2019 04:51
Low pressure inlet problem Bisht FLUENT 10 March 28, 2018 09:04
Convergence issues for low Y plus values in Fluent NicoCFD FLUENT 1 February 4, 2015 10:55
Changing Boundary: Decreasing Inlet Velocity - Convergence Issues VT_Bromley FLUENT 3 February 12, 2011 09:02
High depression at low alpha inlet (interFoam) santiagomarquezd OpenFOAM Running, Solving & CFD 0 June 1, 2010 17:18
