IBM and Fluent
Old   March 16, 2000, 05:10
Default IBM and Fluent
Volker Pawlik
Hello Fluent Users on IBM,
Hello Althea,
does s.o. already use aix 4.3.3. maintenance level 02? It is because with level 02 the hanging up problem which appeared after trying to exit is there again. The bug was fixed with the use of aix4.3.3. maintenance level 00.
The segmentation violation happens due to the impossibilty of closing more than one open graphic window under OpneGL. With X11 it works.
Maybe s.o. has already a better workaround than to use X11?
Volker
Old   March 16, 2000, 07:33
Default Re: IBM and Fluent
Althea
Hello Volker,
I haven't come across that one yet, but I will keep a look out for it. We have a tempoarary systems support crisis at the moment so nothing is changing or being updated here. Please let me know if you find a workaround in the meantime.
Regards Althea
Old   April 28, 2000, 07:30
Volker Pawlik
The problem is now solved by IBM:
one has to install or have installed the following file sets:
ftp://techsupport.services.ibm.com/a...+.4.3.3.12.bff
ftp://techsupport.services.ibm.com/a...C.4.3.3.12.bff
(about 11 MB)
That helps.
Volker
Fluent on Cell Processor DC FLUENT 2 March 14, 2008 12:01
Compiling and Running UDFs on an IBM Power3 S. Hollman FLUENT 0 January 6, 2005 11:23
Import ICEM Mesh to Fluent Fluent Beginner FLUENT 5 June 23, 2004 00:27
Debugging Udfs in Fluent 5.x Greg Perkins FLUENT 0 April 2, 2001 03:03
IBM AIX4.3.3.no OpenGL with GAMBIT 1.2 Volker Pawlik FLUENT 2 January 31, 2000 08:52
