Fluent/Gambit export to CAD
Old   February 1, 2000, 15:10
Default Fluent/Gambit export to CAD
Kai Kang
Does anyone know how to export the geometry information backwards from Fluent or Gambit to CAD systems, such like AutoCAD?
Old   February 2, 2000, 03:53
Default Re: Fluent/Gambit export to CAD
Detlef Schulze
Since GAMBIT is based on the ACIS-format which, I was told, is used by most CAD-System you should be able to export an ACIS-File which is then read by your CAD-Programm.
I hope this helps.
Detlef
Old   February 2, 2000, 22:03
Scott Gilmore
Correct, both Gambit and AutoCAD are based on the ACIS geometry kernel. You can export an ACIS file from Gambit and import that into AutoCAD.
Old   April 17, 2000, 12:41
Gualtiero Guadagni
That is correct, but someone know how to export from Gambit to Pro/E?
Old   April 17, 2000, 14:08
Scott Gilmore
Gambit 1.3, to be released in May, will have export of geometry in STEP, IGES, and Parasolid formats. STEP will be the best choice for Pro/E, as it supports solid models and is supported by Pro/E V20 and higher at no additional cost.
pro/engineer -> turbogrid import file YIM SNAG PIL CFX 10 July 5, 2015 01:52
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Mesh export from Fluent to CAD Piotr FLUENT 0 September 29, 2005 00:27
STAR-Works : Mainstream CAD with CFD CD adapco Group Marketing Siemens 0 February 13, 2002 12:23
Importing I-DEAS unv file hbetb FLUENT 1 August 10, 2001 13:22
