two layer zonal model
Old   October 18, 2000, 22:56
Default two layer zonal model
harith vadari
How can we include a change in the roughness parameter for the wall when using a k-epsilon two layer zonal model in Fluent 5?
Old   October 19, 2000, 04:04
Default Re: two layer zonal model
Rüdiger Schwarze
The roughness parameter is introduced in the wall function approach in order to describe the shift of the velocity distribution of the log law. If You use the two layer zonal model, You calculate the velocity distribution near the wall but outside the viscous sublayer using a special turbulence model. Thus there is no empirical constant like the roughness parameter in Your model.
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Turbulent Boundary Layer on a Flat Plate Hoshang Garda FLUENT 1 November 27, 2013 10:24
Solving boundary layer with k-e model Gearb0x OpenFOAM Running, Solving & CFD 6 January 24, 2013 04:40
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 04:37
