Doubt with fluent
Old   November 8, 2000, 20:34
Default Doubt with fluent
Rome
Hi, I am a new user of Fluent. I do not know how to analyse the residual graph after iteration whether the result I have is true or not.
Any answer is appreciated!
Old   November 9, 2000, 08:25
Default Re: Doubt with fluent
Ron
The residual graph will aid you in judging whether or not your solution has converged.
It will not tell you if what you simulated is correct or not. Just because your residuals drop to an expected limit or level, does not mean that your solution is true or correct. It just means that you have reduced the error in the conservation equations to an acceptable level.
Fluent has some nice features for monitoring Engineering quantities on key surfaces.
You can do the following using the GUI to get there:
Solve>Monitors>Surface
Choose a surface in your model (inlet, outlet, etc..) and choose a quantity which you have a good idea about an expected value (mass flow, pressure, etc.). You can monitor the quantity of interest as the solution progresses.
When you are happy with the value of the quantity you are monitoring, and your residuals are at an acceptable level, then you can feel good about your solution.
Have fun.
Ron
Old   November 17, 2000, 10:52
Max
Ron, do u know about residual?please refer to the discussion topic" residual" and reply to my doubt.TQ very much.
Max
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 06:47
small doubt with fluent iņigo FLUENT 3 February 28, 2011 13:04
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
doubt with fluent G.Balakrishnan FLUENT 3 October 30, 2000 21:40
