July 12, 2001, 04:37 |
Pipe flow patterns
Hello everyone. Has anyone out there succeeded with Fluent 5, the simulation the flow pattern types of two-phase (liquid & gas) pipe flow, i.e. stratified, wavy, slug, annular and bubble. I am currently attempting to do so with Fluent 5's ASM & VOF models and find nothing but perpetual non-convergence, most notably with the continuity residual. If anyone has any experience of this type of modelling, I would be grateful to hear from them. Thanks in advance.
July 12, 2001, 05:37 |
Re: Pipe flow patterns
Hi!
The ASM model is not right for modelling most of your systems. It is not really a multi-phase model at all! It is just really post-processing. You will need to use an Eulerian model to see most of the effects you want. You can use the VOF model for slugging, but as you say I cannot get it to work, either! |
July 13, 2001, 08:01 |
So what IS the the ASM model good for?
July 13, 2001, 08:35 |
Hi!
I think it is for multi-phase flow where the fraction of dispersed phase is very low and will not effect the main phase. I'm not sure it should be called multi-phase, really. |
High speed compressible flow through pipe | Munni | Main CFD Forum | 6 | December 7, 2015 11:33 |
Turbulence intensity in fully devloped pipe flow - Reference | Shocktrain | Main CFD Forum | 0 | October 14, 2010 06:58 |
About Turbulence Intensity (Pipe flow assimilated) | gRomK13 | Main CFD Forum | 1 | July 10, 2009 03:11 |
Turbulence in a pipe flow | JM | Main CFD Forum | 4 | December 21, 2006 04:04 |
outlet boudary condition for a flow in the pipe | Atit | CFX | 2 | November 9, 2004 17:43 |
