Impinging Jet Modeling Problem
Old   August 9, 2001, 23:07
Default Impinging Jet Modeling Problem
Anindya
I am trying to model an impinging jet . There is a nozzle through which air is exiting vertically downwards and hitting the ground. I have two questions about it.
1) what would be the top boundary condition besides (next to) the inlet? Is it pressure or Inlet with zero U and V velocities? If I put Inlet condition bc there with zero U and V , then what values do I put for k and epsilon there ?
2) What are the values of inlet turbulent kinetic energies and dissipation which I need to specify for the inlet jet using k-epsilon model? I am using both FLUENT and STARCD for analysis.
Thanks
Old   August 11, 2001, 03:16
Default Re: Impinging Jet Modeling Problem
david
A)Start with inlet velocity magnitude (along one flow direction only), in other directions put zero. B) Put k=10, e=10 C) Solve it D) Validate and verify before proceeding with further complex problems. By the way, what is the jet velocity u r using ?
DC
Confined Impinging Jet Geometry furley2372 Main CFD Forum 0 May 31, 2011 20:18
Impinging Jet in ICEM - Negative volume Stuttgart CFX 1 September 19, 2008 09:11
impinging jet natesan Main CFD Forum 3 March 17, 2005 05:42
Impinging Jet Modeling Problem Anindya Main CFD Forum 13 August 18, 2001 00:07
impinging jet data Andreas Abdon Main CFD Forum 4 January 19, 2000 07:40
