help on gambit
Old   February 15, 2002, 12:57
Default help on gambit
Hua Gu
Hi, all
I am trying to generate a 3-D duct (some kind of like an elbow) in Gambit, but I have no Autocad at hand, so I plan to use vertex data, since I have some gemetry data on the duct surface. The problem is that I have no manual for the gambit v1.3.0, can anybody give me a help on the format of vertex data files. Thanks
Hua
Old   February 15, 2002, 13:50
Default Re: help on gambit
M. Tabaddor
your gambit cd should have come with a documentation cd, where the answer to your question resides.
Old   February 15, 2002, 14:29
Hua Gu
thanks, Tabaddor. But the problem is that the administrator of the lab did not install completely, so I can not use "help" in gambit, and I am wondering whether I can find that document cd from them. So I would like to learn its format here.
Old   February 16, 2002, 10:55
l.g.patil
hi, you can get more information in webs. use google search with key word as gambit tutorial. bye
Old   February 16, 2002, 12:09
Hua Gu
thanks,that will be helpful.
Old   February 16, 2002, 12:13
Hua Gu
but in the tutorial, only importing IGES file is discussed, which will not solve my problem.
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Does Gambit has a maximum allowable grid number? spartan1516 ANSYS Meshing & Geometry 7 March 25, 2010 09:08
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Problem starting Gambit ViHAR MALViYA FLUENT 0 November 10, 2006 10:26
