Material define
Old   February 20, 2002, 15:35
Default Material define
Q Chen
Hi, I defined a kind of new material in the material panel. Then in the injection panel, I can not find the material I deifned in the material list. Can anyone tell me how to define a new injection material? Thanks!
Chen
Old   February 20, 2002, 16:29
Default Re: Material define
Hua Gu
did you press Change/Creat bottom after you define the material?
Old   February 20, 2002, 17:22
Default Yes, I did.
Q Chen
Yes, I did. I can see the material I defined in the material database. But I can not see it under the material list in the injection panel.
Old   February 20, 2002, 18:02
Default Re: Yes, I did.
Hua Gu
I think that is due to your new material is not saved in the FLUENT database. But I have no idea about putting a local material into database.
Old   February 20, 2002, 20:54
Default I put it in database
Q Chen
I did put it in the data base. But I am wondering if FLUENT is using two set of material databases.
Old   February 20, 2002, 21:02
Default Re: I put it in database
Hua Gu
if you only press change/creat, the data will not be put into database, it is just stored soemwhere as a local data, if you save the case, it will be stored in case file, not in database.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 09:23
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
