Mass balance of DPM (lagrangain) case)
Old   May 24, 2002, 09:06
Default Mass balance of DPM (lagrangain) case)
Hiranya
Hi!
I want to check the mass balance for a 2 phase (DPM) problem. I have an air inlet, an outlet and one liquid injector (2nd phase inlet). How can I do it, could you please tell me.
Thanks, Hiranya
Old   May 26, 2002, 20:59
Default Re: Mass balance of DPM (lagrangain) case)
Jin-Wook LEE
DPM is 'WEAKLY' two phase problem. That is, DPM mass ans eneggy is treated as 'SOURCE' of primary phase(in general, gas phase).
So, there is no inlet for 2nd phase. Injector is treated as 'POINT' source for one trajectory. Your injector can be modeled as (couple of tens or hundreds) of points by 'points', 'groups' or 'surfaces' and so on.
Your mass input to the primary phase from the secondary phase is reported from the 'REPORT--> VOLUME-INTEGRAL--> SUM'.
Sincerely, Jinwook
Old   June 4, 2002, 01:03
Hiranya
Thanks Jin.
mass balance problem in multiphase model mdsanij1 FLUENT 0 July 28, 2009 16:01
Multiphase mass balance GZD Siemens 0 August 6, 2008 13:37
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
mass balance discrepancy? jeff berg CFX 5 February 2, 2005 19:16
