Gray scale Contoures
Old   May 25, 2002, 11:51
Default Gray scale Contoures
zahid
i want to print gray scale; from lighter to darker for low values to high value or vice versa. i am getting from darker to lighter to darker which is very confusing: i.e. for low values darker and for high values also darker and in between lighter. thanks
Old   May 27, 2002, 09:14
Default Re: Gray scale Contoures
Laika
hello,
your gray-scale-colors are just the black-and white version of the coloured contourplots. I'd suggest you to double the value of the uppermost contour-level and to double the number of levels.
You real highest level will be in the middle of the entire scale and you will see the same number of different levels on your plot.
greetings,
Laika, still orbiting
Old   May 28, 2002, 09:12
P.Seiffert
Hi!
You can change the colours in the display. Use Display -> Colormaps... and change the "Currently defined" colormap from bgr to gray. Then the colouring is dark (black) for low values and light (white) for high values.
Greetings, P.S
Old   May 29, 2002, 05:03
zahid
thanks every one
Old   May 31, 2002, 03:52
Laika
aha, that's a better solution,
tnx,
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
advection time scale Tanveer ahmad Rubani CFX 1 February 24, 2009 16:16
EDC and cell time scale Trine FLUENT 2 May 31, 2007 07:53
LES inlet length scale f.neilson Main CFD Forum 0 January 31, 2005 13:26
Gray scale Photon Figures Habib Phoenics 2 October 16, 2002 10:45
