June 19, 2002, 16:41 |
Questions about conjugate heat transfer
I am solving a conjugate heat transfer problem which is just like heating a hotdog in the stove,--the hotdog (surrounded by fluids) also has a direct contact to the heating wall. My question is: How to define initial condition for the fluids and solid since they have different intial value? How to define the condition for the interface between fuids/solid? ( I am using a DO model for the radiation) |
June 20, 2002, 00:10 |
Re: Questions about conjugate heat transfer
Ans. to 1st Q : SOLVE --> INITIALIZE --> PARCH
Ans. to 2nd Q : You do not need to define the condition at the Fluent. You should set the region as SOLID and FLUID separately when you generate the grids by GAMBIT. Then, solver(Fluent) treats the interface, not by user(you). Sincerely, Jinwook |
June 20, 2002, 00:19 |
but I still need to set up the solid walls for the DO radiation model, any idea?
Thanks a lot |
July 19, 2002, 11:19 |
My problem is similar to yours except that i have to attach an insulation material of thickness 1mm inside the center of the anuulus duct...(meaning the annulus is a solid, whereas inside the annulus is fluid..this is where i attach a solid support to block air flow). so when i define the insulation material as solid pf a diff material and the annulus as solid but of a diff material, i seem to get phase domain error when i run in fluent.. I suspect cos fluent has trouble recognising the interface(the edge) where both the solid regions intersect..How do i solve this?
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Conjugate heat transfer and radiation modeling questions | shankara.2 | FLUENT | 0 | April 21, 2009 15:55 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 15:41 |
