Trouble with non-conformal grid interface
Old   July 19, 2002, 16:37
Default Trouble with non-conformal grid interface
Anindya
I have an impinging jet problem. I have two parts where one is a box shape and the other part is the round nozzle. I create the mesh separately.
The bottom surface of the box is set as a wall and the sides are pressure boundaries (open to atmosphere).
The top surface of the box is set as interface-1 boundary condition.
The bottom surface of the round nozzle is set as interface-2.
The sides of the nozzle are set as walls and the top surface as an inlet.
I use Tgrid to merge the two meshes.
I open the merged mesh file in Fluent6.0 (3D). I define the interface using grid interface and give it a name as inteface-1-2. Then two walls are created (say wall-15 and wall-16). wall-16 is the non over-lapping part of interface-1 and interface-2 which is exposed to the atmosphere. I reset the wall-16 boundary condition as pressure-inlet (to simulate entrainment boundaries).
Then when I run Fluent6, it gives the error
"Error: fluent.6.0.20 received a fatal signal (SEGMENTATION VIOLATION). Error Object: #f " .
I am unable to get rid of this error. This problem only runs when I set the wall-16 back to wall. Any other boundary condition does not work. If I set it to wall then my simulation is not right as the top surface is exposed and not covered. So I need a pressure boundary condition there.
Could someone tell me what the problem is and how I can bypass it ? Or is this a bug in Fluent6?
Do reply soon. Thanks a lot.
Anindya
grid interface problems: ydzhang FLUENT 14 November 27, 2018 21:42
How work with grid interface?? teguhtf FLUENT 12 October 29, 2009 01:56
how to activate conformal grid adaption? Ralf Schmidt FLUENT 5 May 16, 2006 17:35
error in Grid Interface chandra FLUENT 1 January 7, 2005 02:18
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
