regarding solid continuum...
Old   August 28, 2002, 01:38
Default regarding solid continuum...
Deadly
DEar all,
Im modelling conjugate heat transfer in a contracting duct, with small annular disc-like volumes fixed inside the contracting duct(modelling a hair-dryer actaully). The disc-like volumes are the heat sources and im required to put in volumetric heat generation in the discs. I created this model in GAMBIT...and defined the discs as solids and the rest of the volume as fluid(air). After iterating, i realise that my temeprature are heating really high..around 2800K!..which is impossible as the material im using is aluminium..Im told it should only go up to around a few 100K. Wht should i do to decrease the amount of temperature? Do i have to define the solids as wall instead? Cos i read from Gambit tutorials tht defining them as solid, only enables conduction inside the solid...no convection. Plz help...
Puck
Old   August 28, 2002, 18:09
Default Re: regarding solid continuum...
wei
Hi, Puck:
I think the problem you met in your case is due to the non-conformal mesh you may have generated. Please read the Fluent online help about conformal/non-conformal mesh.
Wei
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 3, 2013 23:04
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 07:14
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 15:20
setting boundary and continuum in GAMBIT Hakeem FLUENT 0 August 14, 2000 15:32
