meshing pipes
Old   May 27, 2003, 14:46
Default meshing pipes
uma
Hello Everyone, I am a beginner in CFD. I have a few questions,I need to model a long tube (200 mm lenth and 2 mm dia) and then another tube(2.5 mm in length and 0.7 mm dia). These two pipes intersect. I need to mesh this geometry in Gambit.I am not able to do the pipe- pipe intersection. Please let me know what I have to do. This will be a huge help for me.Thankyou so much for taking your time! Best Regards Uma
Old   May 27, 2003, 22:01
Default Re: meshing pipes
Colin
Hi, there. I think you could get some inspirations for your case if you read the Gambit Tutorial Guide: MODELING A THREE-PIPE INTERSECTION (3-D).
Good luck
Old   May 28, 2003, 01:56
Alex Munoz
Hi
read this paper
"turbulent flow in a 90 pipe junction part 1 and part2" Sierra Espinosa F.Z. Bates CJ, O'Doherty TO. Computer & fluids.
Best regards
Alex Munoz BTW, where are you in china?
Old   May 28, 2003, 04:13
solomon
Dear Uma
You can create the two pipes separately by specifying their radius and height. Then you carry out "unite" operation to join them. You may also need to decompose the geometry if you need to mesh them with Hexahedarl blocks.
As colin said the Gambit tutorial has a detailed example how to generate such geometry. I believe that will give you a complete and detail step by step description of how to generate and mesh the geometry.
Hope this will help out.
Old   May 28, 2003, 13:14
uma
Thanku so much!! Thanks a lot Colin,Alex and Solomon!! I will definitely go through the suggested material. Solomon can you tell me about how to decompose the geometry to get the hexahedral blocs, becase i tried doing that by creating a rectangular block and tried to split the larger tube with the rectangular block and then unite the surface developed with the small tube. But this did not work! I am not sure about the mistake I am doing there!! And Alex... I am not in China...I am in USA ;-) Once again thanks a whole lot!!If I have some problmes I will contact you back!
Best Regards, Uma
Old   May 29, 2003, 00:41
Alex Munoz
Hi
OK, if you are in USA you can get the paper by yourself.
Best regards
Alex Munoz
Old   June 2, 2003, 01:43
Alamgir
Uma,
I'm here simplifying the case (decomposing). Just create two pipes and unite them and then create small pipe (same dimention) and place it same coordinate and the split the unite volume with the small pipe, that's it. U can then mesh the volumes with hexa or tetra scheme...
Another way to decompose.... just after uniting creat a cube and place it at the center of the juction and split the unite one with cube.. and then mesh the 4 volumes (pipes) with hexa and middle one with tetra..
bye
Old   June 4, 2003, 18:12
uma
Hello Alamgir, Thankyou so much! I will definitely do this way and thankyou so much for all the help! Best Regards, Uma
Old   June 5, 2003, 21:16
Alamgir
Dear Uma,
Good morning! Here I'm for reminding you that don't forget to delete the unnecessary volumes and surfaces before meshing. Go surface creating submenu and select delete>all and apply.. If there is any unwanted surface will be deleted and do so on for line and points.
Good Luck
Alamgir
Old   June 16, 2003, 00:54
Ajay
If you are using ICEM then I can tell you how to create Hexa mesh on intersecting pipes.
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Gambit - meshing 2 pipes' intersection mrt FLUENT 0 July 10, 2007 07:58
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
