udf to output velocity at some point
Old   August 5, 2003, 14:52
Default udf to output velocity at some point
Jun
I'd like to write out the velocity vs time at several points. I defined some point surfaces, but seems I can't access these points by UDF. Anybody know if I am right or not? If I am right, so how can I output these stuffs? Any advice would be appreciated.
Jun
Old   August 6, 2003, 04:48
Default Re: udf to output velocity at some point
Lohen
Hi, I don't think you need an UDF to do so. You can easily make a macro to save velociy at several point at every time step or more ! and get read the files normally named .out, with any text reader ! Ciao
Old   August 6, 2003, 07:46
ap
You don't need UDF for this. Just define your points in FLUENT and set a Surface Monitor on them, choosing the variable you want to monitor.
A monitor allows you to plot and save to file the values you need.
Each monitor can save only a variable in a single point, so you need to define a monitor in each point for each variable you want to save.
See the manual for more info.
Hi
ap
Old   August 6, 2003, 17:36
Lohen
Hi, sorry , I mistook macro and monitor saving. yeah, that's right, follow the advice of Ap above !!!
bye
Old   August 19, 2003, 13:43
Jun
Thanks a lot, guys.
UDF for Inlet velocity Mijin Kim FLUENT 0 September 28, 2009 04:50
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
How to output unsteady velocity profiles? Jason FLUENT 3 August 8, 2007 09:40
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 12:32
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
