August 18, 2003, 05:59 |
Non-Positive Volume
I have generated a model in proe for a Shell & a tube attached at bottom of shell (Simple Geometry)
Exported as solid in STEP & imported in GAMBIT, applied Grid & Boundary Conditions & exported a mesh for fluent 5/6 While reading in Fluent 6.1 & checking that grid, getting message as "there are non-positive volumes" & checking fails, still I am going for analisys and getting error as diverged solution I am not able to understand the error, please help me out. Also how to give grid in shell thickness?? or just to provide a surface as shell thickness?? |
August 18, 2003, 17:07 |
Re: Non-Positive Volume
Hi, When i see that error, i directly go back to Gambit and change the mesh, nothing to do in Fluent. regards emre
August 19, 2003, 07:00 |
Open the mesh in GAMBIT and check all volumes.
This will allow you to understand where the problem is. GAMBIT will list all volumes which are not valid. Hi ap |
August 19, 2003, 07:42 |
How to check in Gambit for non valid volumes, can I create a volume for thickness for a tank model imported from PROE as STEP/SOLID?
August 19, 2003, 14:59 |
To check volumes in GAMBIT you have to enter the section to create 3D geometries (click on the cube in the Geometry bar), then right-click on the i icon, and select the Check function (with the V-like symbol).
Click on that button, select all volumes you want to check and click on Apply. GAMBIT will list all valid and not valid volumes. Hi ap |
August 20, 2003, 12:01 |
the best solution for this..u do remeshing your drawing...there's some error on ur meshing never give up
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
