August 22, 2003, 06:08 |
udf in fluent
hi, i want to use ufd in fluent but fluent is giving error for the cpp application.can some one guide me in its use.i want to change boundary condtions during simulation
August 22, 2003, 06:50 |
Re: udf in fluent
you must compile your cpp file first!
August 24, 2003, 10:25 |
Re: udf in fluent
Hi!
In most cases you don't need to compile your udf - interpretated udf works just fine (if you use interpretated udf it's pretty easy - just do some examples in fluent documentation). If you need to use compile udf it's abit more complicated - you have to compile it in visual c++ first, and there's also some other things you have to be carefull about - it has all been discussed before in this forum... good luck MATEUS |
fluent udf, saving data in udf | mohsen zendehbad | Fluent UDF and Scheme Programming | 15 | June 13, 2017 23:23 |
Transient pressure UDF for parallel fluent | droberts | Fluent UDF and Scheme Programming | 5 | October 11, 2010 04:13 |
Using Fluent with a UDF frm a remote m/c | aarti | FLUENT | 2 | September 11, 2008 19:53 |
UDF problem caused by various version of Fluent | Yurong | FLUENT | 3 | January 15, 2006 10:57 |
Can somebody send me a Fluent 6 UDF manual?? | KKLAU | FLUENT | 4 | April 14, 2004 16:37 |
