VOF-locating the surface??
Old   November 10, 2003, 12:12
Default VOF-locating the surface??
Kristine
Hi!
I'm modeling a multiphase flow inside a thank (air/water)using laminaer and unsteady flow, dynmesh and the VOF model.
Does anyone know how I can locate the surface in general or close to the wall? I know that the volume fraction for each phase is availabele, but can't find it... any surgestions??
Thanks!
Kristine
Old   November 11, 2003, 02:59
Default Re: VOF-locating the surface??
mateus
Hi!
Im not shure if that is what you want...To set the initial shape of water in the tank you have to go to Adapt-Region Adaption and Mark the region where you want the certain wolume fraction. Than go to Solve-Initialize-patch and set the desired volume fraction. The problem is that you can only determine shapes like lines, and circles in region adaption. This is also explained in VoF tutorial...
I hope i answered your question
Regards
MATEUS
Old   November 11, 2003, 10:02
thomas
Hi, I am assuling you want to follow the free interface air-water during after calculation using fluent (= height, or other parameter ... ). What I could suggest is to set an iso-surface at volume fraction in water or air = to 0.5. That is gonna help you to locate the free surface (= interface water-air). hope this help thomas
VOF & Variable Surface Tension in FLUENT SeamusTCD FLUENT 13 June 18, 2022 01:51
surface monitors in VOF prashanthreddyh FLUENT 2 September 29, 2010 12:07
VOF and Free surface model...are they same? Kushagra CFX 1 November 14, 2008 12:36
How to monitor the surface height of fluid in VOF davidyin FLUENT 0 September 1, 2008 04:14
Surface tension in VOF chapelle FLUENT 0 October 31, 2005 02:27
