Automate this process
Old   January 28, 2004, 04:53
Default Automate this process
Jamcam
Hi all,
I have generated many .dat files with Fluent. I have also created lots of surfaces/lines/rakes across my geometry where I can display various data.
To display these data, I am going in manually, file by file, via the X-Y plot function and writing the desired data to .xy files.
Is there a way I can automate this process while naming each .xy file after the .dat file it was generated from.
Any help on this would be greatly appreciated!
Jamcam
Old   January 29, 2004, 08:30
Default Re: Automate this process
Robert Hart
hmm. If it were me, I would create a simple journal that loads a .dat, and does the output.
e.g.
/file/read-data "datafile.dat" /plot/plot yes "datafile.xy" yes no no z-vel no yes no line1 ()
Then use your program of choice (e.g. perl, bash, basic, whatever) to create a big journal file that repeats this for every datafile.
There's probably a way to do it directly in scheme/lisp but I don't know how to do that.
Old   January 29, 2004, 10:09
Jamcam
Thanks, Robert.
I managed to get something going by recording a journal of the process once, then doing a major bit of cutting, pasting and changing filenames on the journal file. It takes a wee while, but is much quicker than the manual method!
Old   January 29, 2004, 11:42
Robert Hart
I guess it's all about return on investment.
What I mean is, the amount of effort worth putting into making the task easier depends on how many .dat files you had.
For 2 or 3 files, your probably as well off doing it manually, for a few more you can do it the cut&paste way, any more and you want to automate even the cut&paste.
Rob
Flash Process / Problem with thermal phase change model Ridley CFX 0 July 21, 2010 07:57
dxFoamExec orphan process bigphil OpenFOAM Post-Processing 0 March 19, 2009 11:08
Fluent coupled with external process Nitesh Goyal FLUENT 0 July 10, 2007 09:35
how to simulate evaporating process of refrigerant chingyou FLUENT 0 October 25, 2005 21:41
controling fluent process Madhukar Rapaka FLUENT 2 October 13, 2005 09:52
