make a cylinder mappable
Old   January 28, 2004, 15:55
Default make a cylinder mappable
Rajil Saraswat
Hi, I want to make a cylinder mappable as given in Fig 3-55 of the modeling guide of gambit, however i can not make any head and tails how to do it. First i splitted the end caps using real connected points(virtual connected points removes the side surface) to create two real edges. Then i tried to split the side surface using the end cap real edge with the 'split face->edges virtual' option but gambit returns 'Attempted to split face xxx(side face) using edge xxx(splitted edge of end cap) which is already a boundary of the face' I have tried all tries of edge splits on caps, making a line on the side face to split etc. but couldnt get the side face to split. I will be very thankful if you can provide me a solution.
Thanks Rajil
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Oscillating Cylinder in Parallel Flow: Analytical Solution startingcfd Main CFD Forum 7 March 23, 2012 05:49
[OpenFOAM] paraFoam not found maysmech ParaView 26 October 25, 2011 03:14
[ICEM] (ICEM CFD) meshing over a cylinder vmlxb6 ANSYS Meshing & Geometry 6 August 11, 2010 14:37
flow around circular cylinder...plz help yousef FLUENT 4 March 28, 2006 11:01
