Sliding mesh revolution
Old   March 10, 2004, 17:06
Default Sliding mesh revolution
Dennis
I am modeling a fan in 3D and was able to obtain a solution using the multiple reference frame model. When I try to run using a sliding mesh I get a grid interface error. My question is if the simulation runs using MRF are my interfaces definately surfaces of revolution.
Thanks
Old   March 12, 2004, 05:19
Default Re: Sliding mesh revolution
mystic_cfd
Hi Dennis
(on review of message I suggest reading paragraph 2 first...)
Check that the 2 volumes are not connected in Gambit. The sliding interface should consist of 2 faces (one for each volume on either side of the sliding boundary) which are not connected in Gambit. These you use to create a sliding-interface in Fluent.
If you are unsure, you can use the new Fluent feature which allows previews of the mesh movement (without solving any flow equations). Do one timestep and then visualize the grid. If the faces are connected, you see "funny" lines between nodes on the 2 interfaces.
hope this helps.
Old   March 12, 2004, 12:35
Dennis
Thank you very much that's exactly what I needed to get it working.
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Sliding mesh error alice FLUENT 3 February 21, 2012 05:53
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
dynamic mesh and sliding mesh nasser FLUENT 0 November 1, 2005 02:37
